Old 1-Nov-2012, 7:26 PM   #3
I anticipate that WOI will be the most challenging signal. The Low-VHF channels, 2 - 6 are impacted by man made noise, home electronics, auto ignition systems, etc. more than higher frequencies.
This would be a case were I would suggest a rotator, for two reasons. One, at 40' it would make fine tuning aim much quicker and safer. Two, if you have trouble with reliable reception of WOI, you have a means to point the antenna at another ABC affiliate.
That said, I agree with the rest of teleview's recommendation.
Consider the HyGain AR-40 or an NTE U-106 with a TB-105 bearing.
