Thanks for the feedback, hopefully I'm not breaking rules with the two separate posts. I figured this wasn't directly related and since I'm sure I'm not the only person that has had problems figuring this out, I'd separate the two.
I'm going to get up into the attic to see what sort of play I have with the Cat-5 on that end to see if I can go that route.
To answer the length question, it's probably about 30 feet either way to the basement splitter. From there it depends on which TV. I only have 2, of which 1 we don't really use, so I might just eliminate the splitter, which would mean about 50 feet or so total from the antenna to the TV.
