None of your TV channels are strong enough to worry about over-amplification.
A close-by FM transmitter is something to worry about. The stacker antenna is not designed to pick up FM frequencies, but if the transmitter is close enough, then there might still be enough signal getting through the antenna to cause problems with an amp.
Try using the signal locater at FM Fool to see how close the FM transmitters are to your house.
If you do have an FM transmitter very close to you, then I'd suggest a Winegard HDP-269 pre-amp. It has more tolerance for strong signals than other amps.
