Both , W27AU-D and WFXS-DT are Weak signal strength in the Red Reception Zone at your location.
The Weaker the signal strength the Bigger the antenna/s are Required to be to receive More signal.
Amplifiers do not receive signal , if there is not enough signal or no signal from the antenna to amplify then even a - 5 billion power super blaster amplifier - will not produce a signal to watch.
Antennas job is to receive the signal not the amplifier.
As always , attics are not a reception friendly environment and never will be a reception friendly environment.
As always , trees and tree leaves do a real fine job of reducing or blocking reception and so do buildings and other obstructions.
It is best to install antenna/s at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
