Old 31-Oct-2012, 12:22 PM   #3
robk
There are several ways to go...
If you want a simple single antenna installation, a Winegard HD7696P paired with an Antennas Direct CPA-19 preamp would be my choice.
If you want to keep the ANT-751, it can serve as a High-VHF antenna when connected to the a UVSJ. An Antennas Direct DB4e would be a good option as a UHF only antenna. The two antennas would offer aiming flexibility, allowing you to optimize a few more weak channels. Again, I would opt for an Antennas direct CPA-19 at the output of the UVSJ, which should be close to the UHF antenna.
Thanks! I'm going to order the DB4e and CPA-19 and see if that helps things. I'd also like to put both of these in my attic. Do you see any issues with this? I like the idea that both of the antennas are small. I dont have a mast outside to mount either of them on, so i've been trying to stay with smaller antennas.
Also are you at all surprised the ANT-751 wont pickup that station? I thought with a preamp it shouldn't have any issue.
Thanks again for your help!
robk is offline   Reply With Quote
