There are several ways to go...
If you want a simple single antenna installation, a Winegard HD7696P paired with an Antennas Direct CPA-19 preamp would be my choice.
If you want to keep the ANT-751, it can serve as a High-VHF antenna when connected to the a UVSJ. An Antennas Direct DB4e would be a good option as a UHF only antenna. The two antennas would offer aiming flexibility, allowing you to optimize a few more weak channels. Again, I would opt for an Antennas direct CPA-19 at the output of the UVSJ, which should be close to the UHF antenna.
Reason: Added option to reuse the ANT-751
