Old 31-Oct-2012, 1:19 AM   #2
Indoor and attics are not friendly places for Tv reception and never will be friendly places for Tv reception.
That said.
The Tv transmissions are Strong signal strength in the Green reception zone at your location , if the house is wood frame with wood or vinyl siding , try a Terk HDTVi (not the HDTVa) indoor antenna aimed at about 340 degree magnetic compass direction. Here is how to aim indoor and outdoor antennas.
WMYO REAL Digital UHF channel 51 , virtual number (58.1-2-3) , to the north west , also has The CW , http://en.wikipedia.org/wiki/WMYO.
WBNA-DT REAL Digital VHF channel 08 , virtual number (21.1-2-3) ION TV is a Strong transmission at your location and should be received at the angle to the opposite side of the HDTVi antenna.
Install a HDTVi at each Tv location.
__________________________________
For a attic or above the roof install use a ANT751 aimed at about 340 degree magnetic compass direction.
For 1 Tv connection use no splitter. No after the antenna signal amplifier.
For 2 Tv,s connected use a common simple 2 way splitter. No after the antenna signal amplifier.
For 3 Tv's connected use a common simple 3 way splitter. No after the antenna signal amplifier.
For 4 Tv's connected use a common simple 4 way splitter. No after the antenna signal amplifier.
Here are some but not all places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com
_____________
It is best to install a antenna at a location that has the least amount to no amount obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
