Old 30-Oct-2012, 4:08 PM   #6
jsiu
I performed the double rescan and placed the Leaf high on my window facing SE/SSE-NW/NNW as teleview suggested, but unfortunately I still was not receiving CBS.
As ADTech noted, San Bruno Mountain is likely impeding the signal from Sutro Tower. However, I do receive 2.1 Fox clearly (which I believe is broadcast from Sutro Tower), so that would imply I am receiving signals from that location.
teleview: Thanks for your recommendation. Unfortunately, the HDX1000 antenna won't work for me as I'm not permitted to attach such a device to the exterior of my unit (such as the balcony). Any antenna I install would need to be an indoor antenna.
Any other suggestions? Thank you again for your help.
jsiu is offline   Reply With Quote
