The following information has to do with more choices.
For the reception of the Digital Tv stations/channels in the Yellow reception zone of the Digital Tv stations/channels list. Down to KPXD-TV REAL Digital UHF channel 42 , virtual number (68.1) ION , And most likely down to KTXD-TV ME-TV.
But may or may not included reception of , KSFW-LD Real Digital channel 2 , is currently showing infomericals.
The 'LD' of the Tv stations call letters KSFW-LD = Low Power digital Tv station , low power Tv stations often change programing , and may change to a more interesting programing in the future.
Install a Winegard HD7696P antenna with the CPA-19 preamp. And the HFS splitters for more then 1 Tv connected.
With the antenna at about 15 feet above ground and installed above the roof.
The reason I say KSFW may or may not be received is because KSFW does not have much signal strength at your location , and , is because the HD7696P antenna is designed to receive channels , VHF high band channels 7 thru 13 and UHF band channels 14 thru 51. Not VHF low band channels 2 thru 6.
______________________________________________________________
The Winegard HD7082P antenna is designed to receive channels ,
