Old 27-Oct-2012, 11:27 PM   #5
Ok.
At about the 25 foot antenna height above ground , for reception of the Digital Broadcast Tv stations/channels , of the Current Plus Pending Applications Included channel list , in the Yellow reception zone of the channel list , down to and including KTXD-TV REAL UHF Digital channel 46 , virtual number (47.1) http://metvnetwork.com.
Install a Winegard HD7082P antenna with a Antennas Direct CPA-19 preamp. Aimed at about 227 degree magnetic compass direction, Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Buy the HFS splitters at , http://www.hollandelectronics.com , or , http://www.solidsignal.com.
_____________________________________________________________
At 40 feet above ground antenna height , Many of the Digital Tv stations move out of the Yellow reception zone in to the Green reception zone in the channel list.
To receive more Digital Tv stations/channels down the channel to ,
K31GL-D REAL UHF Digital channel 31 , virtual number (31.1) , http://www.hottvchannel.com and www.myretrotv.com.
KATA-CD REAL UHF Digital channel 50 , virtual number (x) , http://amgtv.tv.
Install a Winegard HD7082P antenna. No preamp.
For 1 Tv connection use no preamp and no splitter.
For 2 Tv's connected use a Channel Master CM3412 distribution amplifier.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal buy typing the word ronard in the solidsignal search box.
Here is a , free standing , no guy wires , lay over tower , do all antenna installation and adjustments standing on the ground. http://www.palcoelectronics.com/pe300.aspx
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.channelmasterstore.com.
As always , trees and tree leaves do a real fine job of reducing or blocking reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
