Old 27-Oct-2012, 5:38 AM   #3
If I had to make a recommendation based on the data in your first report, I would lean very heavily toward an outdoor, roof top mounted antenna.
It appears you are close to having a line of sight view of the available transmitters, but you don't have that at the default height of ten feet. It would be best to have you generate a TVFR based on a roof mounted antenna. If you have 'line of sight' at higher mounting level, you'll be able to use a much smaller antenna.
