Television Reception
Or can do it this way. The XG91 is the same set up. However no inside antenna or antennas. Install a Winegard-MS 1000 omni directional antenna above the XG91 on the same mounting pole on the roof. The MS 1000 will receive the local stations to the south west and channel 34 ION Tv. And use the remote control A/B switch at the Tv/Tv's. . OR can use the cheap china antenna in the house , fun to watch it rotate wobble around.
