Old 26-Oct-2012, 6:31 PM   #1
jsiu
Not Receiving CBS (KPIX) Over the Air in Millbrae, CA
Earlier this week, I installed a Mohu Leaf indoor antenna (non-amplified) and thus far, have been very impressed by it. Images come in clear and sharp and I very rarely have signal issues (e.g. pixilation). My only gripe is that I'm not receiving a signal for the major network CBS (5.1). I receive the other major networks (2.1 Fox, 7.1 ABC, 11.1 NBC) beautifully, but not CBS (or KPIX as it's locally known in the Bay Area). Here's some background info.
TV FOOL REPORT: http://www.tvfool.com/?option=com_wr...2df994c7758a00
I live on the 3rd floor of a 4-story condominium complex in Millbrae, CA. My unit is on the south end with my windows facing out of the complex SE to SSE.
ANTENNA PLACEMENT & RECEPTION:
So far, I've found my reception is best when I place the Leaf high on a living room wall which faces NE/NNE-SW/SSW. In this position, I receive all of the major networks perfectly, but no signal for KPIX 5.1.
When placing the antenna on a perpendicular wall in the same room (now facing SE/SSE-NW/NNW), reception is worse. I still do not receive a signal for KPIX and I'll either lose some of the other major networks or the image is likely to be pixilated. This seems counter-intuitive as this is the windowed wall facing out of the complex I mentioned earlier.
These two walls are the most practical to place the Leaf (or any indoor antenna). I've tried positioning it at a few different spots on these walls, but no luck.
Any suggestions out there? Perhaps I need a different antenna? Or an amplified antenna in order to receive KPIX (such as the Mohu Leaf Plus)? I would prefer an indoor antenna if recommending a new antenna.
Any and all help would be greatly appreciated. Let me know if you need to know anything else. Thank you very much.
jsiu is offline   Reply With Quote
