Old 24-Oct-2012, 11:20 PM   #2
A Simple reception situation.
WCBB-DT VHF channel 10 PBS.
and
WPFO-DT UHF channel 23 FOX. To the east are both showing the transmitters are close at 12 miles away and are Strong signal strength and are LOS Line Of Site. That's good.
The other Tv stations to the south west are weaker and have some hills in the way.
For reception of the Digital Tv stations to the south west and east , install above the roof a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp , aimed at about 220 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/point.html.
The Digital Tv stations to the east are Strong signal strength and will be received through the back angle of the HD7696p antenna.
NO antenna rotator is required.
Buy the HFS splitters at , http://www.hollandelectronics.com , http://www.solidsignal.com.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
