Old 24-Oct-2012, 9:31 PM   #3
The Antennas Direct , ClearStream 2 Complete UHF/VHF antenna , http://www.antennasdirect.com/store/...VHF-Combo.html , Has a -->Built In Combiner<-- that combines the UHF and VHF parts of the antenna to 1 coax output of the antenna.
There is No Requirement for a preamplifier that has separate inputs for UHF and VHF. There is NO requirement for a AP2870 preamp that has separate inputs.
_____________________________________
I recommend a , -> Heavy Duty <- Winegard HD7696P aimed at about 145 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antennas/pointing/pointing.html.
The HD7696P antenna will receive All of the , Digital Current Plus Pending Applications Included Broadcast Tv stations/channels in the the , Green and Yellow reception zones of the tvfool channel list.
For 1 Tv connected use no splitter. No antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter. No antenna amplifier.
For 3 Tv's connected use a common simple 3 way splitter. No antenna amplifier.
Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard/ychim.html.
If you choose to install one of the Strong and Sturdy ronard antenna mounts , buy them at solidsignal by typing the word ronard in the solidsignal search box.
Here are some but not the only places to buy antenna and ect. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install the antenna in a manner that has the least amount to no amount of obstructions of any type or kind in the direction of reception.
