Old 24-Oct-2012, 4:04 AM   #2
Based on the -->picture<-- of the tvfool radar plot report.
A simple reception situation.
Install the GS1000 above the roof in such a manner that the roof and the house is not blocking reception to the , north , north west , south , south east.
Aim the GS1000 at about 165 degree magnetic compass direction.
For 1 tv connected use No splitter.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
For 4 Tv's connected use a common simple 4 way splitter.
The Tv transmissions are strong. Most likely a antenna amplifier will not be required.
As always trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception and that includes your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
