Old 24-Oct-2012, 4:01 AM   #6
dannydarkman
Originally Posted by teleview View Post
A Simple reception situation.
For reception of the Canada and USA Digital Tv stations/channels down the tvfool Pending Applications Included Channel List , down to and including , WNYO-TV UHF channel 49 MyNetwork.
Above the roof install a Winegard HD7698P antenna with - no preamp - aimed at about 185 degree magnetic compass direction.
Some common above the roof antenna mounts are , tripod antenna mount , eave antenna mount , chimney antenna mount.
The existing pole mount must be strong and sturdy or do not use it , HD7698P antenna is a Big antenna.
For 1 Tv connected use no splitter , no antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter , no antenna amplifier.
For 3 Tv's connected use a common simple 3 way splitter , no antenna amplifier.
WNYO is weak of signal strength , If not received on the 3 Tv's connected , then install a Channel Master CM3414 distribution amplifier.
Here are some places to buy antennas and etc. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.canadapost.ca/shopper , http://www.amazon.ca , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception to the south east , south , south west.
The Tv's Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channel' or 'Antenna CHannels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
I got 20 channels, but with a much smaller antenna - Channel Master 4221 HD. Can you suggest another antenna either than the Wineguard HD7698P (too big) that would allow me to get more channels?
Also, I did install the Wineguard HD7698P, then how many more if any channels would I receive?
Thanks...
dannydarkman is offline   Reply With Quote
