Old 24-Oct-2012, 3:18 AM   #3
A Simple reception situation.
Install a Winegard HD7000R antenna above the roof , aimed at about 345 degree magnetic direction.
Here are some antenna mounts that do not put holes in the roof , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
For 1 Tv connected use No splitter. No antenna amplifier.
For 2 connections use a common simple 2 way splitter. No antenna amplifier.
For 3 connections use a common simple 3 way splitter. No antenna amplifier.
For 4 connections use a common simple splitter. No antenna amplifier.
As always , trees and tree leaves do a real fine job of , reflecting (multipath) , reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
