Old 24-Oct-2012, 2:08 AM   #2
My first suggestion would be, test the FV30 outside. If the reception improves significantly, as I suspect it will, you'll have a much better idea of well any antenna will perform in the attic. Some attics are satisfactory reception sites but many are challenging.
To test, simply get a section of coax long enough to run from the chimney area down through a door or window to a single TV.
If I was in the same situation I would lean toward an outdoor mounted Winegard HD7000R. I would split the aim between the NW & NE groups.
