Thanks again for the input.
For the trees, the direction I need to aim definitely has trees. In order to mitigate the effects of the trees, do I need to attempt to get the antenna above the trees (not possible), or is there some way to tell from the reports what the incident angle between the antenna and the trees would need to be?
I can move away from the trees to the other end of the house to add some distance and decrease the angle, and I can definitely try to increase the height either through an eave mount or a chimney mount. But if I know what minimum angle would give me the best reception, I have a starting point.
How tall of a mast is practical for the installation?
Brian
