OK, In my defense of asking that last question, I assumed the pre-amp was to boost the weak signals received at the antenna so the Tv can accually tune in the stations that have really weak signals .. so now I guess I understand that if you were able to hook the tv up straight to the antenna, no amps would be needed at all?? the amps are just to make up for loss in the coax, splitters ect. ..... So I could accually get by with a lower output amp then. Is too much as bad as too little? what is the line where you "over power" the tuner?
another question about the KT-200 amp ...... I see it is not designed to be mounted at the antenna, without a weather proof box. SO can I mount this amp in the basement, or do you reccommend mounting it at the antenna in a weather proof box?
