Old 22-Oct-2012, 4:10 PM   #4
Your location Does Not have receivable Tv stations in all 3 channel bands.
The VHF low band channels are 2 thru 6.
WLBZ channel 2 with a signal strength of minus -3.8 NM(dB) , is 106.5 miles away , Will Not be received.
WGCI-LD channel 4 with a signal strength of minus -14.5 NM(dB) , is 73.3 miles away , Will Not be received.
The HD8200U is WAY TO MUCH antenna for your location.
No antenna rotator is required.
_____________________________________________
The other 2 Tv channel bands are ,
UHF band channels 14 thru 51.
Your location has receivable Tv stations channels in the Channel band of ,
__
For reception of the Digital Tv stations/channels in the Green and Yellow reception zones of the Current Plus Pending Applications at your location.
Install a ANT751 antenna aimed at about 360 degree magnetic compass direction.
As always the ANT751 antenna has some forward signal gain and is not a very directional antenna and Will receive the Tv stations to the , north , north west , south west , south , north east.
http://www.solidsignal.com , has a ANT751 antenna with a J type antenna mount , low dollars.
For 2 Tv's connected use a common simple 2 way splitter.
For 3 or 4 Tv's connected use a Channel Master CM3414 distribution amplifier.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
At your location that is , north , north west , south west , south , north east.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO NOT channel scan for cable tv channels
