Full reception DTV antenna system
Yes, even one tree will reduce but not stop the stronger stations on your report. For reception of the weaker stations to your NE, you need to be in the clear in that direction if possible.
Outside above your roofline will be best.
You have channels in all bands (UHF/HighVHF/LowVHF), so I recommend you install a Winegard 8200U all channel antenna with a WInegard AP8700 pre-amplifier.
Reception from all directions on your report requires the use of a rotor or multipul antennas. I recommend you install a Channel Master 9521 rotor.
Reason: part number
