Old 22-Oct-2012, 3:37 AM   #3
Above the roof install a ANT751 antenna aimed at about 174 degree magnetic compass direction.
Toward channel 8.
http://www.solidsignal.com , has the ANT751 antenna with a J type antenna mount , low dollars.
The ANT751 does have some forward gain for improved reception of channel 8.
The ANT751 is not a very directional antenna and Will receive the stronger Digital Tv stations/channels to the north west and east.
For 1 Tv connected use no splitter. No antenna amplifier.
For 2 Tv's connected use a common simple 2 way splitter. No antenna amplifier.
For 3 Tv's connected use a common simple 3 way splitter. No antenna amplifier.
As always , trees and tree leaves do a real fine job of reducing or blocking Tv reception and so do buildings and other obstructions including your own house.
It is best to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
