Actually, with the signal strengths at your location, the directions, and the absense of co-channel/ajacent channel interferrence, you may do fairly well with a good omni-directional antenna.
You could easily install a Winegard amplified MS-2000 omni-directional antenna to test the water. Connect one set and scan for Digital channels. If your reception is exceptable, run the amplified signal to your distribution point.
Reason: Spelling.
