Old 21-Oct-2012, 3:07 PM   #4
The AP8700 preamp amplifies ALL The Tv Channels not just the weak ones.
If you have a Kitz Tech antenna booster then try that in place of the CPA-19 preamp.
You can try whatever antenna you like Outside of the Attic as recommendation for reception.
ALL the rest of the recommendations are the same.
Attics ARE NOT a Friendly environment for Tv reception.
Attics Reduce the Signal Strength. Attics Cause Multipath (reflected signals).
I have made my recommendation for a antenna Outside of the Attic.
Install the antenna in a way that the least amount to no amount of obstructions in the direction of reception.
You can try the Kitz Tech antenna booster with the HD7698P antenna.
