Old 21-Oct-2012, 1:39 PM   #3
meridish
Hi teleview,
Thanks for the reply. I have heard that wingard AP-8700 does not overload the strong signals. It only amplifies the weak signals. May I use this instead of antenna direct preamp you suggested. Please advise.
I use eagle star antenna($40) with kitztech preamp(earlier I used DB8 but i never got these many channels with that). I think kitztech preamp is making me loose weak channels.
With my current setup in the attic I can get following channels with antenna facing 160 degrees.
Reliable Channels
19-TVO
41- Global
9- CTV
20(5.1)-CBC
25- Global(French)
47-Omni 1
40- Omni 2
44(57.1)- Citytv
11(11.1)- CHCH
10(10.1) - CTV 2 (from the back of the antenna)
32(23.1)
14(29.1 and 29.2)- Fox
Not 100% reliable. I do get them but loose them in bad weather.
33(2.1,2.2) NBC
38(7.1) ABC
43(17.1,17.2,17.3) PBS
39(4.1) CBS
49(49.1) - Myn ( I get this occasionaly but quite regulkarlly on cold days)
Thanks in advance.
meridish is offline   Reply With Quote
