Old 21-Oct-2012, 2:28 AM   #7
No static at all
No static at all's Avatar
The amplifier is not overloading. Have you tried moving the antenna to different areas of the attic?
As noted earlier, the relatively weak signal strengths along with the terrain issues between you & DC will likely require an outdoor mounting location for reliable reception.
