Thread: Need Advise
Old 12-Oct-2010, 6:28 PM   #3
Originally Posted by mtownsend View Post
A Winegard HD7698P on a rotator with a pre-amp will get you most of the channels on your list
That's a good choice. If you don't want a rotor, you can fix-aim the antenna at Atlanta, you'd get everything you need.
If you also want Spartenburg channels, I'd get a second HD7698P and use an A/B switch. (or feed the second antenna to a DVR)
The use of preamps is a good idea, especially for the 80' of height that you plan to use.
Don't expect to pick up channel 6. TVfool does not factor in low-band noise when it calculates NM. I like to see at least 10 db NM on channel 6, and more is better. In any event, the programming should be the same as WGTV on channel 8.
