First, verify that you have a reliable signal at the antenna. This is done by connecting only one TV, with no splitter. Once this is done, add the splitter (with the number of ports needed) and recheck the signal quality at each TV. If you have reliable reception, you're done. If the addition of a splitter causes some signals to become unreliable, add a Channel Master CM-3410 distribution amplifier ahead of the splitter.
