Old 19-Oct-2012, 6:52 AM   #2
To prove reception , do the following.
Above the roof install the ANT751 antenna in such a manner that roof or any part of the building Is Not blocking reception in the directions of , north west , north , north east.
Aim the ANT751 antenna at about 1 degree magnetic compass direction , north.
The 1 degree magnetic compass aim direction (north) is a in between aim direction for reception of the Tv stations to the , north west , north , north east.
Connect a NEW matching transformer (balun) to the ANT751 antenna.
Connect a NEW looong RG-6 coax to the New matching transformer.
Run the NEW looong RG-6 coax through a open door or window Direct to a Tv that has a known to be good Digital Broadcast Tv Tuner.
No couplers , no splitters , no antenna amplifiers , no ground block , no nothing.
Do a double rescan , with No antenna connected to the Tv , do a Digital Broadcast Tv Channels Scan , this will clear out the Digital Broadcast Tv Tuner for a clean new scan.
Connect the NEW looong coax to the Tv and scan for Digital Broadcast Tv Channels.
What is reception like now??
It is best to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception and that includes your own house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
-------->DO NOT channel scan for cable tv channels.<--------
