KCPQ (Fox) recently brought a new transmitter on line. It's on Capitol Hill, real CH-22. This makes life a lot easier for you, no more need for an antenna aimed SW at Gold Mountain south of Bremerton.
For attic mounting, an Antennacraft HBU-XX series antenna would be my choice, use the largest model that will fit and still allow aiming. The shortest elements are at the front and should point toward Capitol Hill, about 155° per a compass. The Antennacraft is easier to fold back up if the attic proves to be a poor reception site.
I would prefer you mount outside, you'd have better signal quality and be able to use a smaller antenna. If you opt to go that route, a Winegard HD7694P would be a great choice, though a smaller Antennas Direct Clear Stream2 Complete or RCA ANT-751 would do fairly well if not blocked by a tree.
Reason: Antennacraft folds up easily
