Old 18-Oct-2012, 8:48 AM   #2
I recommend installing the HD7694P antenna above the roof aimed at about 108 degree magnetic compass direction.
With No preamplifier.
With the HD7694P antenna mounted above the roof , the Tv transmissions are strong and no antenna amplifier is required.
Remove ALL parts of the antenna amplifier , Remove the preamp , remove the power inserter , remove the power supply.
I am thinking that there is , bad coax , bad connectors , bad couplers , bad etc. , in the system or a bad preamp or all of the list and more.
As a test of reception , with the antenna mounted above the roof , connect a New looong coax direct to the antenna and run the looong coax through a open door or window direct to the Tv , no couplers , no splitters , no antenna amplifier.
What is reception like now??
____________________________________________________________________________
For 2 Tv's connected use a common simple 2 way splitter.
For 3 Tv's connected use a common simple 3 way splitter.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here some places to by reception equipment , http://www.solidsignal.com , http://www.amazon.com.
As always , trees and tree leaves do a good job of reducing or blocking reception and so do buildings and other obstructions.
It is best to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception and that includes your own house.
The Tv/s Must Channel Scan for the Broadcast Tv Channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
