Old 18-Oct-2012, 6:01 AM   #3
Originally Posted by confused View Post
What antenna can I set up that I do not need to move it to get all possible stations? Also can I combine this antenna with another one to improve strength?
To get 'all possible stations' with one antenna will require a rotator.
Combining antennas is possible in theory. You need to use some rather expensive filters at a minnimum. To trully achieve 'all possible stations', would require equipment simmilar to that used by a cable TV headend.
The antenna and preamp suggested by teleview can be expected to do quite well without the need to spend a lot, or complicate your channel surffing experience by the addition of rotator operation. I suggest you start by seeing what a high quality antenna system can deliver, If you still want to add more signals from other directions you can add to your system without loosing your investment in the Winegard and Antennas Direct products that have been recommended.
