Thread: Which antenna?
Old 18-Oct-2012, 1:25 AM   #4
These 3 USA Digital Tv stations/channels are most likely receivable at your location.
KVOS-DT , Me-Tv and The Cool Tv.
KBCB-DT , Shop NBC and Estrella Tv.
K24IC-D , PBS.
To test for reception , put the Clear Stream 2 Bundle antenna in a south facing window aim the antenna at about 141 degree magnetic compass direction.
If there is a south or better yet a east balcony that is even better.
As always , trees and tree leaves do a good job of reducing or blocking Tv reception and so do buildings and other obstructions.
It is best to mount the antenna at a location that has the least amount to no amount of obstructions of any type or kind int the directions of reception and that includes your own building.
The Tv/s Must Channel Scan for the Broadcast Tv channels , sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
