Yes I would use the same set-up even with one direction.
You can add the rotor later. If adding later use an Eagel Aspen Roto100 rotor. This rotor uses the coax for operation which eliminates the need to add the rotor cable, however you must use the Winegard AP8700 amplifier for compatability with that configuration.
