Old 16-Oct-2012, 7:40 PM   #8
It's hard to argue with success.
You're correct, the UHF and High-VHF performance of your existing antennas matches or exceeds those I've suggested. The critical difference is that each of the suggested antennas includes support for Low-VHF. Hopefully your current system will continue to provide reliable reception. If not, the antennas I've mentioned are appropriate solutions when mounted outside in the clear.
Cheers
