Old 16-Oct-2012, 6:07 PM   #19
guido_groundplane
Signal Strength Test
Both antennas bought new by me about 15 years ago.
Could not prove any real difference in signal strength between the two while pointed at Channel 48 / 13 degrees. Tried a couple different channels in that direction, swapped cables on a single converter box for an apples-to-apples comparison.
However, did notice the 4248 did not get 9, 11, 20 and 26 ( off-angle over at ~320 degrees ) but the 8 bay did (especially if connected to the Magnavox not the RCA)
So decided to keep the 4248 pointed at 13 degrees and pointed the 8-bay at ~320 degrees, since it's reception seems to be a bit "wider".
The FM trap switch is now 30ft above the roof, where it will hopefully stay for an other 15 years. But I gather I can try a separate FM trap near the converter box?
I also noticed the RCA converter box, though in most respects inferior to the Magnavox, gets several channels that start with 1, such as 1-1, 1-2, and so one. The Magnavox does not. Maybe an on screen setting somewhere I need to change.
Thanks,
"GG"
guido_groundplane is offline   Reply With Quote
