Old 16-Oct-2012, 3:12 PM   #5
JimInAmesIA
Can you post a link to your TV Fool reception report? http://forum.tvfool.com/showthread.php?t=4
What is the model number of the GE antenna, and the GE amplifier?
Thanks
Hi again GUM.
Is this what you mean by my Fool Reception Report?
http://www.tvfool.com/?option=com_wr...2df974d491cd25
Thanks for making that available btw, it was very useful in aligning my antennas when it showed me all the channels I wanted were pretty much in a line 170-173 degrees.
GE Antenna 34792 http://www.walmart.com/ip/GE-Attic-M...tenna/20976617
GE amp 33341 http://www.walmart.com/ip/GE-Video-S...ifier/16561353
I'm no longer having any reception problems, not even with WOI 5 after I added the splitter to move the RCA preamp power off the direct coax into the TV.
My question was concerning if such preamp power supplies with the coax running through them to the TV ever cause reception problems perhaps due to shorts or malfunction of the power supply itself? I asked since, I think as I already wrote, when I moved the power supply to the other TV the problems with WOI 5 moved with it.
It's a pain I need all this hardware for the one channel but I do want to be able to get it in, seems I am now.
JimInAmesIA is offline   Reply With Quote
