Old 15-Oct-2012, 7:39 AM   #3
JimInAmesIA
Have you ever tested the basic reception of the antennas? By connecting just the antenna to one TV, no amplifier or power supply parts, and no splitters...Very few systems have a legitimate need for two amplifiers. Many systems would be better with none.
Yes I have. I get excellent reception on all channels except WOI 5 which now also seems to be doing much better after I put the splitter between the preamp power supply and coax into TV.
Combining dissimilar antennas that cover the same band (UHF, High-VHF and Low-VHF) quite often causes more reception problems than it solves.
Powering an amplifier via the coax with a splitter in line requires the use of a power passing splitter.
Without either amp or preamp I can't get channel 5 at all, the preamp gives me a better picture on the other channels but the amp seems to have no effect.
JimInAmesIA is offline   Reply With Quote
