Old 15-Oct-2012, 1:38 AM   #5
A Simple reception situation.
Above the roof install a ANT751 antenna aimed at about 250 degree magnetic compass direction.
http://www.solidsignal.com , has the ANT751 , with a J type antenna mount , low dollars.
For 3 Tv's connected use a common simple 3 way splitter.
Best locate the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels sometimes named the 'Antenna Channels' or "Air Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Do not channel scan for cable tv channels.
