Old 14-Oct-2012, 11:53 PM   #9
thxtheater
Success!!!!!!!!!
Originally Posted by teleview View Post
To make a Point.
Just because some one at - A Location - receives channels , X , Y , Z , does not mean that some one at a -> Different Location <- will receive the same , X , Y , Z , .
Thanks to everyone for the help. I finally had a non-rain day to get up on the roof and take a look at the antenna. One of the phasing lines was just touching one of the bolts on the antenna. So even though I was neurotic about making sure that the phasing lines weren't touching, sure enough, it was.
So I then properly set the antenna to true North and calibrated the rotator so that all degrees would properly correspond.
Then, all I did was rescan for additional digital channels and I got 7 new channels--among them FOX out of NYC (5.1).
Now I have everything I need to finally dump Cable!!! Thanks a ton everyone for your input and help. I can't thank you all enough.
thxtheater is offline   Reply With Quote
