Old 13-Oct-2012, 7:30 PM   #5
silencery
Are you willing to mount an antenna outside?
If we were neighbors, you would see an Antennas Direct 91XG UHF and Antennacraft Y10713 High-VHF above my roof. Each would be equipped with an Antennas Direct CPA19 preamp. The outputs of the two would combine using a UVSJ downstream of the power insertion blocks of each amplifier.
@GroundUrMast,
Thanks for the tips. An outside antenna is not out of the question.
I'm just concerned about wasting time and energy to set it up and having it not work. If i'm reading the charts right, it looks like even an outside mast at 30 ft (the tallest I can get it) wouldn't be much of a result. Is that right?
silencery is offline   Reply With Quote
