Old 13-Oct-2012, 6:45 AM   #11
Install a matching transformer on each antenna, http://www.solidsignal.com/pview.asp...u=615798101084. Then use a short section of RG-6 coax from each antenna to a HLSJ (High Low Signal Joiner), http://www.solidsignal.com/search/sr...earch=1&cart=8.
The top antenna in your photo is the High-VHF, the lower antenna is a Low-VHF. Connect each antenna to the corresponding port of the HLSJ. The tuner is fed from the common port of the HLSJ.
