Old 12-Oct-2010, 12:47 AM   #5
mtownsend
Originally Posted by Tugboat View Post
About how high do you think we need the outdoor antenna to be to pull in the Portland stations reasonably well?
You need to have the antenna high enough above your own roof to make sure the roof itself does not interfere with the performance of the antenna. Ideally, you want to have the antenna at least about 4-5 feet above the average roof line in your neighborhood.
In special situations where there is a nearby obstruction (e.g., a tall building or hill in the way that is less than half a mile away), then some extra height might make a significant difference. When the main obstruction is close by, a little bit of height can change the angle at which the signal must diffract (or bend) over the top of the obstruction. Signals cannot diffract well at sharp angles, so reducing the diffraction angle results in more signal power reaching the antenna.
However, in your situation, the nearest major obstruction appears to be several miles away. In this case, adding height makes very little difference at all. Adding 10, 20, or even 50 feet will barely change the diffraction angle for an obstruction that's ~12 miles away, so I doubt that you will see any significant change in signal strength.
If you want to try some what-if scenarios, then you can try out our Interactive Maps feature (here). In this tool, the list of channels and their Noise Margin values (shown below the map) will automatically update when you enter different values for the antenna height. You can see if there is any significant change in signal strength for the channels you want.
I think that for your situation, being 4-5 feet above your own roof is probably all that you need.
