Thread: Anttena Help
Old 11-Oct-2012, 9:41 PM   #6
John Candle
Tv Reception
I see that the tvfool radar report is for no feet antenna height above ground.
Please make 3 tvfool radar reports with antenna heights of , 01 , 10 , 25 , feet above ground.
Doing research , I see that WSPA has repeater stations that might be received.
http://en.wikipedia.org/wiki/WSPA-TV.
The following are some tests for reception and not the recommendations I will recommend for reception depending on how tests go.
The following tests are using the preamp. Have only one Tv connected , no splitters.
W08AO-D channel 08 , at 5 degree magnetic compass direction.
W02AG-D channel 02 , at 154 degree magnetic compass direction.
I recommend doing a double rescans when trying for these repeater Tv stations.
The double rescan clears out the Digital tuner so the Digital tuner can do a fresh new scan for channels.
Disconnect the antenna coax from the Tv , and do a scan for digital broadcast Tv channels , this clears out the tuner.
Aim the antenna at a repeater Tv station , reconnect the antenna coax to the Tv , and scan for digital broadcast Tv channels.
And do the double rescan when trying for WSPA channel 7 CBS.
Aim the antenna at about 127 degree magnetic compass direction.
Also test reception of WASV-LP channel 50 NBC and Me-Tv and MyNetwork at 65 degree magnetic compass direction.
___________________________
And looks like WSPA is also on WYCW-DT REAL Digital UHF channel 45 , virtual number (62.1-2) , http://en.wikipedia.org/wiki/WYCW
