Old 10-Oct-2012, 3:25 AM   #10
cakeordeath
Originally Posted by teleview View Post
The CM4228HD does better at receiving at the low end of the UHF.
Channels 14 thru 30 where you require it the most , that is why I recommend the CM4228HD for your reception.
http://www.antennahacks.com/Comparis...228_vs_DB8.htm.
http://www.antennahacks.com/Comparis..._vs_HD8800.htm.
And the CPA-19 preamp is a low noise mid gain preamp that will tolerate high signal strengths with out over load , and works with other antennas , that is why I recommended it.
____________________________
Getting closer to the Truth helps in the middle of the day.
I'm a strong believer in numbers because the numbers don't lie. Looking at both the CPA-19 noise specs and the low UHF db gain on the CM4228 you are spot on. My apologies for second guessing you.
cakeordeath is offline   Reply With Quote
