Old 11-Oct-2010, 11:01 PM   #6
mgrover
My suggestion would be a DB-2 UHF aimed at 220° for ABC, NBC, FOX, & PBS plus a Y10-7-13 aimed at 24° for CBS. Use a AP-2870 preamp to add them together.
If you want the other stations at 24°, I'd get a second antenna such as a HBU-22 or HD7694P and use an A/B switch at the TV set.
I found each of the antennas you referenced at solidsignal.com and the prices are definately within reason. My question is: If you only could have two which two would it be? Since I have a DVR I want to "set it and forget it." I'm most concerned with forgetting to rotate or press an A/B switch and miss something that I would want to record. That leads to one additional question - is it possible to have 3 antennas paired down to 1 antenna input? All I have seen is ones that handle a pair so I was just wondering.
Thanks!
mgrover is offline   Reply With Quote
