Old 10-Oct-2012, 12:16 AM   #29
westom:
The OP said:
I only need 4 channels to live..ABC, NBC, Fox and CBS.
At first glance it looks like he needs CH6 for ABC, but if you research W07DC-D on CH7, you will see that it carries ABC, which is why teleview and GroundUrMast said that he would need VHF-high and UHF antennas. Rabbitears.info indicates that it is active:
http://www.rabbitears.info/market.ph...llsign=W07DC-D
You can research other VHF-low channel assignments here:
http://www.rabbitears.info/statistics.php
The noise level on VHF-low is usually higher than on VHF-high and UHF, esp. in urban areas, which requires a stronger signal to maintain a SNR greater than 16 dB. But, if the noise level is not excessive, then VHF-low transmission can be quite satisfactory and economical as teleview indicated.
