Old 9-Oct-2012, 7:11 PM   #28
The Truth is that the Biased and Flawed studies that were done several years ago , low band channels 2 thru 6 and high band channels 7 thru 13 are exactly that , Biased and Flawed Studies and information.
There are Tv stations that went to the UHF channels June 2009 at then applied to the FCC got approval to go back to the VHF low band channels 2 thru 6. They are not stupid , they are very smart , because Tv stations are finding out that with the correct transmission parameters VHF low band works very well for Tv transmission and reception. And the cost to run a Tv transmitter on VHF is thousands and thousands dollars Less per month then UHF. I have known this for a long time and I will no longer apologize for VHF transmission and reception.
